(Openbaar)De vouwwagen => vouwwagenmerken informatie => Sylvan sport go => Topic gestart door: der ghopmeister op juni 22, 2009, 09:17:19 pm
(http://www.geekytraveller.com/wp-content/uploads/2007/09/sylvansport-go-miniature-camping-trailer.jpg)
Specificaties
SPECIFICATIONS standard metric
Interior Floor Dimension 48 x 84 in 121.92 x 1.22 cm
Trailer Size (closed travel mode) 138 x 74 x 51 in 3.42 x 1.88 x 1.29 m
Trailer Size (open travel mode) 138 x 74 x 79 in 3.42 x 1.88 x 2 m
Trailer Size (camping mode) 167 x 124 x 106 in 4.2 x 3.14 x 2.69 m
Weight (unloaded) 800 lbs 382 kg
Front Storage Pod Capacity 9 cu ft 255 cu lt
Camping Pod Storage Capacity 15 cu ft 425 cu lt
Standing Height (camping mode) 87 in 2.2 m
Torsion Axle Suspension
Tires 20.5 x 8.0-10 - 20.5 x 8.0-10
Ball Coupler 2 in 5 cm
? Low profile design for minimum drag and super fuel efficiency
? All aluminum hyper-engineered? frame
? Torsion suspension for smooth load control
? Very light weight at 800 lbs.
? 13? ground clearance and high flotation tires for off-road use
? UV resistant plastic storage boxes for years of maintenance free watertight storage
? Waterproof gear storage in top camping pod
? Lockable waterproof gear storage in front storage pod
? Rack system frees up space from your tow vehicles? roof rack
? Rack system compatible with Thule, Yakima, and other brand accessories
? 800 lb. load capacity
? Control-Tilt? cargo bed with hydraulic dampening system
? Easy to own with very low-maintenance
? Excellent suspension geometry and handling characteristics make it easy to tow
? Cast aluminum wheels
? Self lubricating hubs
? Spare tire
? LED lighting for safer, long lasting service
? Waterproof electrical system suitable for use as a small boat trailer
? Reinforced diamond-plate flooring for heavy loads
? Multiple tie-down points
? Multiple configurations for carrying gear
This is just really cool. If you like to play with a Swiss Army knife (what? I do!), you?ll love the SylvanSport GO Miniature Camping Trailer.
The trailer weighs 700 pounds (!) and can be pulled behind most small cars. When you arrive at your campground, the tent pops right up and is set up in mere minutes. It also has a weather-proof gear box to keep your important pieces safe, and when you?re headed home, the whole thing just stows back inside the roof?s storage box.
Not only is it a tent though, you can use the trailer to haul boats, bikes,anything you can imagine up to a weight of 800 pounds.
It costs approximately $6000.
(http://www.inklinginc.com/SylvanSportGotent.jpg)
(http://i301.photobucket.com/albums/nn52/onwheelsinc/Jackson/DSC_4514.jpg?t=1245698009)
(http://i301.photobucket.com/albums/nn52/onwheelsinc/Jackson/DSC_4513.jpg)
Dealer
De Vouwwagenspecialist B.V.
Mijlstraat 24-25 5281 LL Boxtel
00.31.(0) 411-683601
www.vouwwagenspecialist.nl
Links:
Website (http://sylvansport.com/it.html)
Sylvan sportgo FAQ (http://www.sylvansport.com/svc_faq.html)
filmpjes vind je hier (http://www.sylvansport.com/videos/index.html)
downloadable technical drawings (http://sylvansport.com/media/downloads/go_specs.zip)
http://www.vouwwagenspecialist.nl/gotrailer.htm
* 2 - 4 Slaapplaatsen
* Disselbak
* 4 Camper Jacks
* 2 Self-inflating luchtmatrassen
* Oplooprem en 750kg Knott as met schokdempers
* Te gebruiken als bagage- / aanhangwagen
* Uitklapbare opstap
* Leeggwicht ca 325kg
Go Outdoor Tenttrailer 8995,=
Aerotex (grondtapijt) 50,=
Aanritsbare luifel 295,=
Bagagebox Aluminium 99x49x42 162Ltr. 350,=
Bagagezak p.o.a.
Disselslot SCM gekeurd 125,=
Fietshouder Thule p/st. 59,=
Gascomfort 145,=
Gasfles Campinggaz 907 95,=
Kooktafel Aluminium 125,=
Reservewiel met beugel 195,=
Tafel (incl. uitbreiding slaapplaats) 495,=
Telescopisch neuswiel 85,=
Tempo 100 keuring 140,=
Tyron Safety band (set) 210,=
WheelSeal (per band) 25,=
Rijklaarmaakkosten 285,=
Verwijderingsbijdrage 10,=
