Auteur Topic: GO Sylvan Sport  (gelezen 16686 keer)
der ghopmeister
GO Sylvan Sport
« Gepost op: juni 22, 2009, 09:17:19 pm »
Specificaties
SPECIFICATIONS                               standard               metric
Interior Floor Dimension                     48 x 84 in                121.92 x 1.22 cm
Trailer Size (closed travel mode)        138 x 74 x 51 in       3.42 x 1.88 x 1.29 m
Trailer Size (open travel mode)          138 x 74 x 79 in       3.42 x 1.88 x 2 m
Trailer Size (camping mode)               167 x 124 x 106 in   4.2 x 3.14 x 2.69 m
Weight (unloaded) 800 lbs 382 kg
Front Storage Pod Capacity 9 cu ft 255 cu lt
Camping Pod Storage Capacity 15 cu ft 425 cu lt
Standing Height (camping mode) 87 in 2.2 m
Torsion Axle Suspension
Tires 20.5 x 8.0-10 - 20.5 x 8.0-10
Ball Coupler 2 in 5 cm
? Low profile design for minimum drag and super fuel efficiency
? All aluminum hyper-engineered? frame
? Torsion suspension for smooth load control
? Very light weight at 800 lbs.
? 13? ground clearance and high flotation tires for off-road use
? UV resistant plastic storage boxes for years of maintenance free watertight storage
? Waterproof gear storage in top camping pod
? Lockable waterproof gear storage in front storage pod
? Rack system frees up space from your tow vehicles? roof rack
? Rack system compatible with Thule, Yakima, and other brand accessories
? 800 lb. load capacity
? Control-Tilt? cargo bed with hydraulic dampening system
? Easy to own with very low-maintenance
? Excellent suspension geometry and handling characteristics make it easy to tow
? Cast aluminum wheels
? Self lubricating hubs
? Spare tire
? LED lighting for safer, long lasting service
? Waterproof electrical system suitable for use as a small boat trailer
? Reinforced diamond-plate flooring for heavy loads
? Multiple tie-down points
? Multiple configurations for carrying gear
Citaat
This is just really cool. If you like to play with a Swiss Army knife (what? I do!), you?ll love the SylvanSport GO Miniature Camping Trailer.
The trailer weighs 700 pounds (!) and can be pulled behind most small cars. When you arrive at your campground, the tent pops right up and is set up in mere minutes. It also has a weather-proof gear box to keep your important pieces safe, and when you?re headed home, the whole thing just stows back inside the roof?s storage box.
Not only is it a tent though, you can use the trailer to haul boats, bikes,anything you can imagine up to a weight of 800 pounds.
It costs approximately $6000.
Dealer
De Vouwwagenspecialist B.V.
Mijlstraat 24-25 5281 LL Boxtel
00.31.(0) 411-683601
www.vouwwagenspecialist.nl
Links:
Website
Sylvan sportgo FAQ
filmpjes vind je hier
downloadable technical drawings
« Laatst bewerkt op: juli 25, 2009, 10:24:54 pm door muis »
der ghopmeister
Re:Sylvan Sport GO
« Reactie #1 Gepost op: juni 22, 2009, 09:46:12 pm »
http://www.vouwwagenspecialist.nl/gotrailer.htm
    *  2 - 4 Slaapplaatsen
    * Disselbak
    * 4 Camper Jacks
    * 2 Self-inflating luchtmatrassen
    * Oplooprem en 750kg Knott as met schokdempers
    * Te gebruiken als bagage- / aanhangwagen
    * Uitklapbare opstap
    * Leeggwicht ca 325kg
Go Outdoor Tenttrailer      8995,=
Aerotex (grondtapijt)    50,=
Aanritsbare luifel    295,=
Bagagebox Aluminium 99x49x42 162Ltr.    350,=
Bagagezak    p.o.a.
Disselslot SCM gekeurd    125,=
Fietshouder Thule p/st.    59,=
Gascomfort    145,=
Gasfles Campinggaz 907    95,=
Kooktafel Aluminium    125,=
Reservewiel met beugel    195,=
Tafel (incl. uitbreiding slaapplaats)    495,=
Telescopisch neuswiel    85,=
Tempo 100 keuring    140,=
Tyron Safety band (set)    210,=
WheelSeal (per band)    25,=
Rijklaarmaakkosten    285,=
Verwijderingsbijdrage    10,=
« Laatst bewerkt op: juni 22, 2009, 09:48:46 pm door der ghopmeister »
